Results 1 to 6 of 6
    VXRed Xor's Avatar
    2nd August 2012
    31
    Default A question about rattling noise and vibration from engine area.
    Hi
    Rattling noise:
    I will first say this has only happened around 10-20 times since i bought my car.
    On initial start up can it sound like "starter motor keeps hanging on" until the rpm drops
    or if it is something with the clutch that makes the sound until the rpm drops. The sound is heard for about 5 seconds.
    Vibrations:
    I can feel this in my back through my chair when engine is at normal operating temp on idle when im waiting for traffic lights to turn green.
    It can be explained as "engine misfires" it feels like that, but I do not think that's the fault.
    I would like your thoughts on this ?
    // Andreas
    Opel Astra OPC MY16.5 Flash Blue
    From Sweden
    16,622
    Is the car totally standard?
    VXRacing ahead
    26th April 2014
    595
    I think i have the same issue only at start up , i explained it on an earlier thread as keeping the ignition @ the top position on early cars, and you would get a metalic scrape/knock.
    It doesn't happen everytime i start the car , and only tends to happen if it has been sat around for 2-3 days without driving, or in summer when its its baking hot.
    I also get a slight push when in traffic, but only when the car is cold. It doesn't sound like a misfire, and to be honest there is no noise when this happend.
    There are no codes on iobd2 either.
    VXRed Xor's Avatar
    2nd August 2012
    31
    It has a stage one remap from a known tuner.
    From Sweden
    VXRed Xor's Avatar
    2nd August 2012
    31
    Quote Originally Posted by Mrs S Cat View Post
    Yes i do think we have the same issue and that was a good explanation of the sound
    From Sweden
    VXRacing ahead
    26th April 2014
    595
    Mine is vanilla
