Results 1 to 6 of 6
    VXRed Jackfowlerpt's Avatar
    7th October 2017
    10
    Default Astra J F40 VXR gearbox oil??
    Hi all,
    After reading soooo many reviews on gearbox oil what works and what doesnt, does anybody have a link to buy the recomended gm stuff?
    Also from what i read fluchs titan sintofluid FE SAE 75w stuff is also good, if so is this a superior fluid to the gm stuff as i dont mind paying the extra for that? Anybody had personal experiance with fluchs?
    Cheers lads.
    Sent from my SM-G950F using Tapatalk
    3rd May 2017
    89
    This thread explains which GM oil to get and how to change it as well:
    http://www.vxronline.co.uk/forum/sho...ge-gearbox-oil
    As for where to buy it from, I got mine from AutoVaux:
    https://www.autovaux.co.uk/catalogse...lt/?q=93165694
    I personally just brought 2 litres from there and chucked the whole lot in (drained first ofc!). No experience with other oils but most on here recommend the GM stuff.
    7th October 2017
    10
    Quote Originally Posted by V*X*R View Post
    Spot on is that mate thankyou, appriciate it, looks like theres nohing to it will give it a go one night next week. And ill go on the safe side and use the GM stuff reccomended keeps the people at vauxhally warranty department haoly aswell then. 👍
    18th November 2017
    1
    Default Every how many Miles do you do it?
    Quote Originally Posted by Jackfowlerpt View Post
    Hi all,
    Cheers lads.
    Hello
    I have A Astra gtc Opc J from 2017 it s the last 2.0bnft.
    (Vxr J for Uk) . I see that you changed Oil of f40 Gearbox, I would like to ask you every how many Miles do you it?
    Because in Opel garage they didn t know that it s need to bee changed. Yes it s incredible but yesterday they did my first oil changed and when I asked for my gearbox they didn t know that had to be changed 😂😂😂. They look very stupid and unacceptable for a official garage to don t know that because the mr6/ f40 gearbox is very used in Alfa Romeo, Opel, Vauxhall, Saab.
    So I will do my self because they re just stupid.
    Thanks a lot for what you had already explained.
    Regards from Belgium.
    VXRed amonkey's Avatar
    16th August 2012
    51
    I changed mine every two years.
    Filled in 2 litres of Motul Gear 300 LS. Everythings fine. You have to look for the LS because of the drexler limited slip differential.
    11th July 2017
    174
    The general car manufacturers rule is that the gearbox oil at best only ever gets a check at about 100,000 miles...they class it as sealed so never do a change of oil.
    Same with power steering and most non engine specific fluids.....even brake fluid isnt changed unless you tell them to do it, they at most might check its water content.
    Even the engine coolant doesnt get changed unless you tell them...it just gets a check.
    All about money these days and not about the car
