Results 1 to 6 of 6
Thread: corsa e opc
    13th October 2017
    3
    Default corsa e opc
    hello all,
    I considering buying a new Corsa OPC. I would like to ask if anyone experience major problems with the car?(engine, gear,steering wheel,etc.. )
    6th October 2016
    71
    I have a 2016 plate Corsa VXR and apart from the bonnet sensor adjustment I have had no problems at all. 11,500 miles completed and still loving it.
    Yorkie
    13th October 2017
    3
    Thank you for the information, I have more questions :
    which oil is recommended for this engine ? the engine has a timing belt or chain (when it should be replaced) ? should I run this engine ? for how much miles?
    sagi
    6th October 2016
    71
    This is all I could find about recalls:
    http://ukcar.reviews/vauxhall-corsav...blems-recalls/
    Yorkie
    6th October 2016
    71
    Cool
    Some good information towards the bottom of this reference cam belt changes and oil:
    http://www.courtenaysport.co.uk/servicing/info_178.html
    Yorkie
    VXRed ALEX-E92's Avatar
    20th May 2017
    36
    I'm the same as Yorkie13, the bonnet sensor adjustment is the only little problem I've had. Also I have noticed from other Corsa E VXR owners that this seems to be a common fault on this model. However it is a simple and easy fix. Yet overall there has been no other issues with my car whatsoever and the drive is always full of never-ending good fun! 😁
