Results 1 to 10 of 15
Thread: Misfire on idle
    22nd April 2015
    72
    Thumbs down Misfire on idle
    Hi guys don't post alot but do read the forums, anyway I have a 15 plate clubsport with 38k on it, only mods is a decat and is starting to misfire on idle only, car drives perfect apart from that, just wondering if anyone could shed some light for me and just hope it isn't the dreaded piston 4.. As can't afford a rebuild the now.. Thanks in advance
    6th May 2017
    804
    Coil pack?
    Piston 4 is possible, but to be certain a compression test is needed.
    Get it looked at sooner rather than later. If it is p4, delaying repairs and still driving the car could cost considerably more as the damage could result in a bottom end rebuild and oversized pistons etc.
    25th September 2013
    1,084
    replace coil pack and plugs use genuine only and see if that sorts it , if not more investigation .
    15th January 2014
    648
    Quote Originally Posted by nippyrascal View Post
    This, I'd go with plugs and coilpack first.
    If it helps, the part number for plugs is BKR8EIX.
    Coilpack should be a delphi one.
    Also could be MAF, although it doesn't sound much like a MAF problem! But again, if you do replace that, go with Bosch as it doesn't like aftermarket ones
    20th June 2017
    153
    you say you have d cat it have you done that recent and also have you had it mapped since?
    22nd April 2015
    72
    Just an update guys, done a compression test and is p4 starting to fail..
    20th March 2015
    360
    Quote Originally Posted by Ckem247 View Post
    Out of interest, what were the values?
    22nd April 2015
    72
    Quote Originally Posted by 20Drift View Post
    1,2,3 175 psi. 4 was 115 but lost pressure after engine stopped cranking
    20th March 2015
    360
    Ah man that's a shame. You going to forge or just repair?
    25th September 2013
    1,084
    Another piston 4 bites the dust , just unlucky you going to forge , repair or replace car.
