Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 70
  1. #11
    VXR enough Ant21's Avatar
    29th September 2013
    1,473
    Ah right. I wondered what the second slot was for. Spose it makes sense.
    Where do to place the gps aerial? Sorry if it sounds noob, due my first CID cd70 soon and just want to know the ins and outs.
    I’ve got my gps aerial next to my centre speaker. Tried to place it under the glovebox and around the dash area but it just doesn’t get a signal. Needs to be as close to the window as possible. Cable is ran under the dash so you can’t even tell.
  2. #12
    17,113
    So the aerial has to be exposed on the dash by the bottom of the windscreen?
  3. #13
    29th September 2013
    1,473
    Nah not at all. Mine is under the centre speaker grille. It just needs to be close to the window so that it gets a decent signal. You can check for satellite signal on the navi hidden menu.
    In other words. You cannot tell that my unit has been retrofitted.
  4. #14
    17,113
    Where are they when factory fitted?
  5. #15
    17,113
  6. #16
    VXRed tifty101's Avatar
    10th March 2017
    33
    I had this in my Vectra 2.0T, I had the GPS aerial within the center speaker but nothing, moved it to sit basically on top and it was totally different
  7. #17
    29th September 2013
    1,473
    They are in the main aerial base. Think they look slightly different but unless you know what to look for then you won’t notice.
  8. #18
    29th September 2013
    1,473
    Quote Originally Posted by tifty101 View Post
    Strange. Mine works fine where it is, I get at least 7 satellites visible as seen within the hidden menu.
  9. #19
    17,113
    Ah right. Yeah I've seen the aerial bases. I'm a stickler for or look to each detail so I may have to swap the base. Do you know how?
  10. #20
    29th September 2013
    1,473
    Yep. The how is not too. It’s a pig of a job and requires removal of the headliner or at least the part near the boot. Plus it’s unlikely you’ll have the wiring in place as you’ll need the second fakra wire for the gps
