Page 7 of 7 FirstFirst ... 5 6 7
Results 61 to 70 of 70
  1. #61
    12,902
    Nah not at all. Mine is under the centre speaker grille. It just needs to be close to the window so that it gets a decent signal. You can check for satellite signal on the navi hidden menu.
    In other words. You cannot tell that my unit has been retrofitted.
    Sorted my gps antenna today, managed to place it behind the pillar trim and run the wire behind the door seal, glove box, and cable tie it nicely behind the head unit. Signal works so it's all good.
    Sent from my SM-T520 using Tapatalk
  2. #62
    VXR enough Ant21's Avatar
    29th September 2013
    1,357
    Hmm. This seems like a design flaw to me .....
    Took mine out earlier and decided to check this one..
    So my radio was on, although the volume was right down (aka mute). Went to set a navi destination and she was talking, telling me where to go and not once did my radio pipe up. So just check all your settings for the navi voice as it is possible.
    Possibly, you need a firmware update? Think the latest firmware is 2012 but I might be wrong.
  3. #63
    12,902
    Right. Trying to sort my aux on the cube at the moment. Have locates all wires and where they need to go, but I've no idea how to pull each wire from the cube, a pin won't shift them and I don't know how much force I need to use :/
  4. #64
    29th September 2013
    1,357
    Ahh good luck! If you can, try a really really skinny screwdriver to unhook the little metal clip on the pin and then wiggle it out.
    I managed to break one of mine, but managed to salvage it and crimp it back on.
    Just for info, I checked Maplin and also an 'old boys electrical shop' near me and neither had the right pins. They are a right ***** to get out.
  5. #65
    12,902
    These buggers aren't coming out.
    Why the bloody b**tard hell can't they just be in the same stupid position for all radios ..
    Pain in the chuffing *****
  6. #66
    29th September 2013
    1,357
    Patience.....
  7. #67
    12,902
    I don't have much when I ain't getting results ....
  8. #68
    12,902
    Think this is a no go. Is there an adapter cube you can buy that swaps the wire positions to the right ones?
  9. #69
    29th September 2013
    1,357
    Not that I'm aware of....
  10. #70
    12,902
    https://www.amazon.co.uk/Bluetooth-A.../dp/B018R4XXIG
    Like this for example. But that's for bluetooth
