Results 1 to 10 of 13
    VXRacing ahead
    5th March 2016
    514
    Default Corsa vxr wing mirror removal
    I know its been said before but Ive tried pulling mirror up but car is lifting and mirror not coming off
    I have taken off door card but cant see any holes so how the hell are they put on in first place?
    Mine is loose but the base on the door is solid so need to tighten mirror to the base HELP Im at the point of cutting a hole in back of door to get at screws
    18th November 2017
    2
    Did you sort this mate
    VXR enough chodiddly's Avatar
    12th December 2015
    1,465
    is ther nothing on youtube mate?
    VXRacing ahead
    5th March 2016
    514
    Nope, nothing anywhere all videos are corsa D but not vxr , I am going to take the whole door off and bring it into the house over Xmas and work it out and take pictures or a video of how to do it properly as the only stuff on here is to pull it up and off but that will break the mirror as Ive tried it and the whole care moves with it , even if I have to cut a small panel out of the door after removing door card to get to screws at least it wont be seen when door card back on
    6th February 2008
    15,855
    Probably you have not found anything on YouTube, it gives people instructions on how to nick your mirrors
    Sent from my iPad using Tapatalk Pro
    VXRacing ahead
    5th March 2016
    514
    But if Vauxhall just make the bolts accessible when removing the door car like most manufacturers they can be removed but not stolen unless someone breaks into your car and r moves the door card
    18th November 2017
    2
    You need a bit of brute force to separate the base from the main bit then the 35 torch can be seen although u need to take the door card off for the plug.where are u mate I can do it I work for a vx bodyshop
    VXRacing ahead
    5th March 2016
    514
    Quote Originally Posted by Woodyvxr View Post
    I live near Lincoln
    VXRed corsaez's Avatar
    8th December 2013
    198
    Pm'd you matey
    VXRacing ahead
    5th March 2016
    514
    Dont think mine are working as nothing come through
