Results 1 to 3 of 3
    Are you VXR enough? ARCTIC MARK's Avatar
    16th August 2011
    838
    Default P1 P2 Personalised Menu for Keyless Astra
    How do you access this menu? normally don't you put your key in but don't turn it then pull the 2 levers towards you?
    But what about keyless??
    Opel Astra Burg #686, Eibach springs, Bilstein shocks, Whiteline adjustable rear anti roll bar, Turbo smart actuator & recirculation valve, Brembo 4 pot brakes, DNA Performance FMIC, Enlarged top hat & pipework, 3" Turbo back stainless exhaust, 6k AFL's, Smoked side repeaters, Silvatec indicator lamps, Heko wind deflectors, Insignia washer jets, Crossover delete, Piper cross cone filter, SM Tuning Stage 3 - 300BHP / 310ftlb Torque.
    6th February 2008
    15,951
    Not sure if Astra has P1 P2 Menus,
    I thought everything was setup using the Config / Setup button on the radio
    VXR enough Ant21's Avatar
    29th September 2013
    1,464
    As above. Not applicable for the Astra, Corsa only.
