Results 1 to 10 of 19
    12,911
    Default changing aerial base
    Right so when I tried to swap my aerial for a new stubby one I found that my old one was seized on, and in my attempts to unscrew it I seemed to have damaged the base so the aerial just spins and doesn't unscrew. Ffs
    Looks like a new base will be needed. Anybody changed one before? How easy is the headlining to remove without damaging it?
    26th February 2012
    1,687
    Yeah only a nut and wiring plug hold it on, headlining can be teased down enough without causing damage
    12,911
    Do you know How to loosen it?
    26th February 2012
    1,687
    think i removed rubber seal around rear hatch opening then used 17 mm spanner being delicate not to crease roof lining
    12,911
    Right. Well I need to order a new base first anyway.
    12,911
    Did you do it from the boot or in the back seat?
    26th February 2012
    1,687
    boot
    12,911
    Ok. Thanks for the advice bud
    7th November 2014
    338
    Is there a "how to" for this?
    I need a new base but dont know how to fit.
    Do I actually need a new base???Its the seal round the aerial base that looks well tatty
    22nd April 2017
    20
    You can get a seal on fleabay. The seal isn’t available separately from vx it just comes with the base
