Results 1 to 10 of 10
    15th January 2014
    648
    Exclamation Need help, clunking suspension issue
    Doing my head in this one!
    Had a bit of creaking sort of from the front end, so I changed the top mounts on both sides, didn't help.
    Creaking got worse so had the CV joints replaced.
    That seems to have got rid of the creaking, but now i've got a knocking sort of sound.
    Car has also had new track rod ends and ARB Drop links around 4-5 month ago so don't think it'll be them.
    The clunk happens worst when coming to a stop or pulling away, doesn't happen side to side etc.
    Any ideas appreciated!
    17th September 2016
    81
    Check the front lower subframe brace, might have been bent up the way and fouling on the exhaust
    Other than that check engine mounts, the bottom gearbox stabiliser mounts can fail, and check wishbone bushes
    22nd April 2015
    72
    Could also be something like the brake pad fitting kit
    23rd May 2013
    2,373
    Knocking is usually balljoints.
    You've changed all except the wishbone-hub balljoint but the sounds of it so that'd be on my list, especially if the car is a high miler.
    Unfortunately you can't change them by themselves...they come as part of the wishbone so if you replace those you are ruling out 2 potential problems (wishbone bushes and the balljoint).
    IIRC i got 2 wishbones delivered a month ago off ebay for £50 so cheap fix for something quite big.
    23rd May 2013
    2,373
    In fact here you go, they're down to £40 delivered now;
    http://www.ebay.co.uk/itm/2006-VAUXH...72.m2749.l2649
    15th January 2014
    648
    As suggested above I checked the subframe brace last night but that was fine (spaced it down slightly with some metal washers when I got the exhaust fitted as it was knocking initially on that).
    Going to go for the wishbones next as you say, thats all it can be now surely! cheers for the link too mate!
    Cheers for the suggestions everyone else too
    21st June 2017
    23
    It's either the wishbone or antiroll bar.
    16th December 2017
    1
    A little over a year ago I bought a Corsa VXR second hand. Since the moment I bought it I had clunking sounds coming from the front left and for the life of me I couldn't figure out what it was. My dad who's built cars from ground up, brother who's practically pulled apart every aspect of his Astra and my girlfriend's dad (a mechanic), none of them could figure it out. They all suggested CV joint, drop links etc. Just like everybody online was suggesting.
    Then I my shocks died so I decided to upgrade to B14 coilovers. From the day I installed them the clunking disappeared and has never returned.
    You might not want to hear this because if you've got the same issue it's not a quick cheap fix, but it's likely the shocks. I don't know how cheap you can get original shocks in the UK, but in Australia I'd have ended up paying the same price for new, OE shocks from overseas.
    I'd personally recommend B14s since they're an amazing upgrade from stock and will probably fix your issue.
    27th December 2016
    6
    Hi pal I has the exact same problem it was the bottom engine mount had gone. Go get that checked asap
    22nd July 2017
    16
    Quote Originally Posted by BigBaron View Post
    Eurocarparts have a Christmas sale!
