Results 1 to 4 of 4
    VXRed MichaelM5727's Avatar
    3rd July 2017
    11
    Default VXR turbo upgrade
    Hey guys,
    Does anyone know if you can get a hybrid turbo for the VXR and if so is it any better than any other ones out there!
    Cheers!
    23rd May 2013
    1,821
    Quote Originally Posted by MichaelM5727 View Post
    Hey guys,
    Cheers!
    What do you mean "better"?
    Yes you can get a hybrid with K04 internals but it won't make the most power vs the likes of a Garret conversion or similar
    9th November 2013
    22
    Hi, yeh you could get hybrid from wg motorworks that gives really good figures but needs a lot of supporting mods to go with it ie fuel pump, injectors, fmic, turbo back exhaust, forge internals depending on what power u go for, so realy depends on what u already have or what your willing to spend, im led to bbelieve a stage 3 corsa is upto 250bhp and 260lbs torque and with hybrid you can get upto 270bhp and 290lbs torque, in all honesty your better getting a k04 upgrade, it also depends where u r located and how far your willong to travel too, there are a lot of good tuners out there to use
    11th December 2017
    9
    Depending on your budget i'd personally go the garret route will need supporting cams with higher lift and imo i'd have stronger internals ,fuel pump and injectors to stay on the safe side but gains are unreal and turn these things into road eaters i'd save for the m32 box to go wrong quicker than average and an uprated diff to keep it in a straight line also being honest but hybrids aren't too bad but kkk are no match for a garrett
