Results 1 to 1 of 1
Thread: Diff cover
    VXR enough COSWORTH's Avatar
    17th July 2013
    1,073
    Default Diff cover
    Hi all
    Just a quick question, need to take diff cover off the bottom of my gearbox, when I fit new gasket do I need gasket paste on it or is it a dry joint?
    Planning ahead for next gearbox oil change would it be worth buying a new diff cover plate and welding in a threaded hole so I can fit a drain plug ?
    Before you all say it has a drain plug, mine is a F17 box as its not a vxr
