Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    9th January 2017
    800
    Quote Originally Posted by Brucerutherford View Post
    Cheers! and the mesh was just from ebay, my mate ordered it as it came in a pack of two and he done his astra with it as well, will double check which one he ordered and let you know mate!
    As for fixing it on, I'll have to get a picture to show you better, but basically I've cut all the tabs off that the original grille attaches too apart from along the top and the sides, and then I used a tiny drill to drill a little hole through each of the tabs that are left and put a cable tie through and then just attach the mesh there so inside it isn't perfectly flush to the bumper along the top but you can't see that and it is flush along the bottom so looks all good!
    Alternatively, another mate of mine cut all of the tabs off altogether, used mastik or something to glue little blocks of wood to the inside and then screwed the mesh onto those. Looks quite tidy but I didn't wanna do that cause I had a fear of the wood coming detached from the bumper haha.
    Thanks a lot mate.
    Silver Lightning Corsa VXR
  2. #12
    VXRed bobbys clubsport's Avatar
    6th May 2015
    48
    Yeah I have this one mate, looks pretty good on silver I’d say
    Or this
    Can I ask where you had your front number plate from and what size it is. Thanks Rob
  3. #13
    20th June 2017
    154
    why does the bumper always look a different colour at certain angles
    mine does the same but its red
  4. #14
    15th January 2014
    648
    Quote Originally Posted by bobbys clubsport View Post
    I'm sure it was 520mm x 80mm mate, I'd have to double check but %99 sure that was the size!
    The website was platecreator.com I believe.
  5. #15
    15th January 2014
    648
    Quote Originally Posted by raz0083 View Post
    Yeah I think most of them do! something to do with the different material of the bumper I think as opposed to the metal?
