Results 1 to 10 of 10
    VXRed Hornyshauny's Avatar
    26th August 2012
    100
    Default ECN017012 - Fuel Trim Malfunction
    Can any shred any light onto what the fault is an what needs changing etc
    Also ECN156571
    13,478
    Fuel trim normally means you have an exhaust leak or downpipe leak before the 1st lambda sensor distorting the readings. Hence the fuel trim.
    20th January 2014
    1,696
    First hand experience
    OPC ÉIRE
    13,478
    Quote Originally Posted by VeXeR View Post
    Exactly
    13,478
    Op if you have an aftermarket exhaust on, or even if it's stock I'd check the v band clamp. Maybe warped and need replacing. This solved my trim code.
    26th August 2012
    100
    would this cause the car to cut out?? Its cut out twice wen pulling up an thats the code iv got... iv also got a boost leak im guessing this would play apart of it
    13,478
    If its cutting out I'd look at the maf sensor. Find someone with one you know is good, swap it and see if it stops it.
    26th August 2012
    100
    Could issues with the maf cause boost issues?? See ive watched the boost gauge an im struggling to boost over 5psi an normally hits around 15psi but aint got any error codes apart from fuel trim
    13,478
    Yes definitely mate. It's essential to be in working order so it can interpret the airflow and adjust the air fuel ratio properly.
    26th August 2012
    100
    thanks for all the help guys i let uno what happens after changing the maf sensor
