Results 1 to 2 of 2
    12th July 2017
    5
    Default Engine Management Light
    Hi Guys
    can you help, just had a full 3inch straight through system installed and now my engine management light is on, is this normal until i have it mapped out
    Another thing ive got the spanner light on which when plugged in says i need a new boost solenoid sensor, but since the engine management light has come this other Light has gone off,
    thanks
    Anthony
    VXR enough andrewt1971's Avatar
    25th January 2010
    3,204
    Check the clamp that holds the exhaust to the exhaust housing isn't fouling the turbo actuator. 90% of the time error codes immediately after an exhaust swap are caused by this.
