Results 1 to 8 of 8
    6th December 2017
    1
    Default excessive blue smoke on accelerating when warm
    Just bought my Astra VXR it was fine when I bought it but the other day I was driving it quite hard no problem. Today though I put my foot down slightly and I get lots of blue smoke but if you drive it steady you don’t get and when keeping a a constant speed no smoke. It’s just on harder acceleration.
    IF ANYONE CAN HELP IT WOULD BE APPRECIATED
    VXRed Brett_VXR's Avatar
    14th November 2017
    145
    Blue smoke on acceleration is most likely the turbo, usually the seals, especially if it happens when the engine is on boost.
    Does it not do it on startup or idle?
    VXR Stage 2 • Courtenay Sport Map 292bhp - 337 lbft
    Courtenay Ko4 • Courtenay Tophat • Scorpion Exhaust
    200 Cell Cat • AEM Filter • Luk Clutch • Luk DMF & Cover
    Forge Recirc • 18” TD Pro 1.2 • Eibach Springs
    VXRed blooded tye_time's Avatar
    24th February 2017
    485
    Definitely sounds like turbo seals I'm afraid - not sure if fitting an oil restrictor bolt would help?
    14th November 2017
    145
    If the turbo is smoking due to worn turbo oil seals, then the turbo already has a problem. Unfortunately a restrictor bolt will not repair the worn oil seals.
    24th February 2017
    485
    yeah that's what i was thinking - time for a turbo rebuild i reckon.
    19th January 2014
    1,912
    That's not to say that it may not need a restrictor bolt to start with.
    If it has an aftermarket exhaust system, it'd be well to check for a restrictor bolt first as it will cause those symptoms if not fitted with a restrictor.
    OPC ÉIRE
    VXR enough Cnking's Avatar
    3rd August 2011
    1,270
    Yeah I had the same I fitted a full remus , then I had this problem I fitted a bolt and happys days no smoke
    25th January 2010
    1,095
    Would the reg be FE58CKP ?
