Results 1 to 7 of 7
Thread: VXR corsa whine
    6th December 2017
    8
    Default VXR corsa whine
    hello all just got my first vxr corsa love the car ive been thinking of getting a car for years. I've only had the car for a couple of weeks after having a RAC check before buying it and they said all is well with the car so I went ahead and brought it recently have notice when the car is cold there is a whine when reving it or acclerating it dosent have to be in gear dose it in nutral as well as in gear had the car service and ask vauxhall to have a listen and they said they heard nothing. the whine gose once the car is warm. they had it over night so they could start it from cold I'm pritty sure there's something wrong weather it's a bearing or even I notice a alternator making that sort of noise but as I'm new to the vxr I'm not too sure has anyone had any problems like this or where would the best place to go? also notice with the clutch pedal all gears are nice clutch seems all good but when putting the clutch to the floor when going over a speed bump I can feel a slight moment in the clutch pedal also some times changing gear it happends only slightly tho but that's all so somthing I would like to get check out. sorry for all the question but I've had a gearbox blow up on me with my first vauxhall astra sxi and it cost a bomb and don't want that to happen again would rather get it sorted if there's is somthing wrong.manythanks
    VXRed Brett_VXR's Avatar
    14th November 2017
    88
    Have a read of this mate, may not be the gearbox but worth a read to see if symptoms are the same..
    http://www.wgmotorworks.co.uk/repair...n/m32-gearbox/
    VXR Stage 2 • Courtenay Sport Map 292bhp - 337 lbft
    Courtenay Ko4 • Courtenay Tophat • Scorpion Exhaust
    200 Cell Cat • AEM Filter • Luk Clutch • Luk DMF & Cover
    Forge Recirc • 18” TD Pro 1.2 • Eibach Springs
    31st December 2014
    1,430
    Had something similar on mine w hile ago.
    Started off as a little whine when cold but gradually got more annoying, turned out the be the pulley on the alternator. Got a low mileage alternator really cheap and changed it out, instantly alot more quieter.
    Hope its something as simple as this.
    4th October 2013
    108
    I have the same issue, two gearbox rebuilds later and it's still there, I've been driving around with it for a while as it isn't causing any major issues (FOR NOW) but I reckon it's similar to what Desert_Cloak had.
    it also depends on the noise, if you have it on all gears it may not be gearbox, but if it is specific to certain gears then It could be, definitely worth having a look at the link Brett_vxr sent for more detailed info.
    6th December 2017
    8
    hello all thanks for all your help it happends when I'm not even in gear I am thinking it's a bearing of some type I have just gone and got a mechanics stethoscope to try and locate where the noise is coming from if I find it I will let you know what the course was thanks again all that replied
    6th December 2017
    8
    I found the problem it was coming from the alternator but the car has a new noise witch is a slight knocking noise from the engine so I'm gonna sort all this out and get rid. I've always loved these cars and will do but in a week ive spent about 1000 pounds and yet more needs done dosent seem to stop.
    31st December 2014
    1,430
    Unfortunately sometimes this can happen and you lose faith in the car.
    I had a 3 series (e46) before my corsa, got it for 2.5k and spent mear on 3.5k getting it repaired every weekend.
