Results 1 to 9 of 9
    VXRed Seaskewer's Avatar
    12th June 2014
    154
    Default AFL adjustment for Europe
    Hi all, hoping someone can help.
    I’ve moved to France, taken the car with me, my alloys are in a right mess with the high curbs and thin roads, gonna cost me a fortune to get them sorted out.
    Before I go to an Opel dealership and get ripped off, is there a way to adjust the AFL system so the beam is the right way for driving in Europe?
    Thanks in advance.
    Arden Blue, Stage 3, Thorney Motorsport tuned, 304BHP
    VXRed Brett_VXR's Avatar
    14th November 2017
    155
    Not sure if it works in the J but in the H, if you have AFL..
    1. Pull and hold stalk for main beam on steering wheel (with ignition off)
    2. Switch ignition on
    3. After approx. 3-4 seconds an acoustic signal will sound and the AFL control indicator will flash for 4 seconds
    process complete.. to turn back just repeat..
    as I said maybe different for the J tho :/
    VXR Stage 2 • Courtenay Sport Map 292bhp - 337 lbft
    Courtenay Ko4 • Courtenay Tophat • Scorpion Exhaust
    200 Cell Cat • AEM Filter • Luk Clutch • Luk DMF & Cover
    Forge Recirc • 18” TD Pro 1.2 • Eibach Springs
    6th February 2008
    15,958
    As above,
    12th June 2014
    154
    Thanks for the responses I’ll give it a go now n see what happens.
    12th June 2014
    154
    Hi, just tried it nothing happened. Found this on the Vauxhall’s manual, says the same, can’t work out why it isn’t working? Any thoughts? I’m sure I have AFL as I have the lights washers and the lights do a bit of a moving routine when I start it up.
    12th June 2014
    154
    3rd May 2017
    160
    Sounds like you do have AFL if you have the washers and the beam moves when the headlights come on.
    I just tried this on mine and it does work. Here is what I did exactly:
    1. Key in ignition and key to position 1.
    2. Pull lever and hold (headlight will flash).
    3. Keep holding and turn on ignition.
    4. You'll get the usual startup process where the main display says "checking" and then shortly after most of the warning lights go out.
    5. Keep the lever pulled until you get the audible sound and the AFL dash light flash 4 times. Do not release until you get the audible sound.
    System is now configured for Europe. To verify, switch all off then switch ignition back on. About 5 seconds later you'll get the flashing AFL light to indicate this mode is still enabled.
    If you want to disable the feature you repeat the above steps but you do not get the audible sound or flashing light so it's just a case of waiting for about the same amount of time and then releasing the lever. The dash light will no longer flash on startup.
    Hope this helps.
    12th June 2014
    154
    Thanks, I didn’t have the inanition let in position 1, I’ll try it shortly.
    12th June 2014
    154
    Looks like that worked, I didn’t get the beep, but get the flashing icon now I start the engine, thanks for your help. I think you need to disable auto light when you do this as well.
