Results 1 to 5 of 5
    3rd December 2013
    225
    Default Rear spring isolators
    Hello
    Got Astra H GTC Z20LER
    I want to buy isolators for rear springs as the original ones are worn out
    Are there polyurethane ones?
    I want to buy online if possible as I'm from Lebanon
    kindly advise
    VXRacing ahead tye_time's Avatar
    24th February 2017
    579
    Hi - here are the part numbers for the top and bottom mounts:
    Top: 90576351
    Bottom: 90538496
    You should be able to get the same part from eBay using these numbers.
    22nd April 2017
    72
    Hi sorry to hijack this post. Are these the same for Astra vxr?
    26th February 2012
    1,771
    Quote Originally Posted by Carlmu View Post
    have you got ids suspension? If not then YES these are the right ones
    22nd April 2017
    72
    Nice one cheers👍
