Results 1 to 9 of 9
    Are you VXR enough? ashwrx's Avatar
    14th December 2010
    838
    Default Max power for ko6
    What’s a safe limit to run a ko6.a have a forged engine.am running stage 3 at 310.just waiting on my ko6 would a need cams and bigger injectors
    Burg 666 stage 3
    VXRed Brett_VXR's Avatar
    14th November 2017
    147
    Most ko6 I’ve seen run between 300-340 but not having one fitted means I’m no expert..
    VXR Stage 2 • Courtenay Sport Map 292bhp - 337 lbft
    Courtenay Ko4 • Courtenay Tophat • Scorpion Exhaust
    200 Cell Cat • AEM Filter • Luk Clutch • Luk DMF & Cover
    Forge Recirc • 18” TD Pro 1.2 • Eibach Springs
    15th May 2013
    17,824
    They tend to top out anything between 330 to 350
    The manifold is what holds them back.
    Do you have fast road cams in too?
    VXRed blooded tye_time's Avatar
    24th February 2017
    493
    yeah a new inlet manifold (Klaasen or EDS) will help towards the top end of the rev range
    15th May 2013
    17,824
    Quote Originally Posted by tye_time View Post
    I was on about the exhaust manifold but you'd need an inlet as well
    16,045
    355 on stevenbarrows car. But he had a stage 3 k06 and meth cooling. Cams and inlet too of course.
    VXR Torque of the Devil cklrossi's Avatar
    24th June 2012
    6,198
    348 on mine with no meth
    Arden Astra VXR WGM350 stage 4.5
    Progress thread.......Instagram Chris.Lee 1973 http://www.vxronline.co.uk/forum/sho...uilt-Astra-VXR
    W G Motorworks
    VXRed supercharged999's Avatar
    15th March 2011
    87
    So is it worth Forging just to run a k06 ?
    16,045
    Hybrid turbos enable higher boost at higher revs. High revs stress the rods, the rods and bolts are the weak point on the leh engine because unlike the pistons they are not forged as standard.
    People never used to bother forging for a hybrid but if you're going for the higher powers that they can reach now then it's probably best to.
