Results 1 to 10 of 10
Thread: boost leaks?
    21st June 2016
    187
    Default boost leaks?
    mine has an intermittent (getting worse) boost leak, what exactly do i need to be checking? iv had the 2 piece flexi pipe from maf to turbo apart and thats fine
    Are you VXR enough? Jon1796's Avatar
    24th August 2015
    978
    What about boost solenoid. I know it's not the same lump.
    http://www.astraownersnetwork.co.uk/.../t-152418.html
    11th July 2014
    342
    I think a smoke test is normally recommended for a boost leak.
    24th August 2015
    978
    Smoke yes agree but if it’s intermittent I’d think more like a dodge sticking valve a leak in one of the pipes would be constant.
    VXRed blooded Finn67's Avatar
    4th November 2012
    302
    Are you certain it's a boost leak? What are the driving symptoms? Jon the leak 'might' not be constant you know, consistent but not always constant, the expansion and retraction of metals etc could cause an intermittent and if say there was the beginning of a pipe fracture, the engine pulling back may be enough (for the moment) to open a hole on hard acceleration but maybe not quite on lower.
    I had one of the pipes at the rear at it's connector cause an intermittent boost problem, it just hadn't 'clicked', at steady acceleration it was fine but if I wanted more from her, it was causing a boost issue.
    Thankfully found the problem straight away at the time lol.
    4th November 2012
    302
    Gaspode what about the MAF sensor itself? Have you cleaned it? You could do with a scan really
    21st June 2016
    187
    no im not sure its a boost leak thats part of the problem lol , swapped maf and it made no difference
    VXR enough V6spike's Avatar
    18th May 2013
    1,713
    Likely a leak. Check check and check the pipe work. Then get a smoke test. I got mine done by wayside performance. Then get the actuator pressure tested.
    Then by process I’d swap out the MAP sensor (on the intake from the throttle body)
    There are other things to check and I’m sure @dog_book will shed some light.
    '55' Sapphire Black VXR Estate. Eibach Prosport all round, remapped by Rabbid.
    4th November 2012
    302
    Keep us posted on any outcome Gaspode as other members will get a hit on this thread when searching a similar problem, often the outcome isn't posted and it can be a little frustrating...
    Hope it's a cheap fix all the same
    21st June 2016
    187
    iv chaNGED THE MAP AND THE 2 SESNORS NEXT TO EACHOTHER (boost control and i cant remembver the other) also changed the actuator lol
    on a plus point i think a new expansion tank cap has fixed my water leak
