Dear Members,
Need help with the crank shaft sensor problem sensor is been changed twice but still the same problem . Now I want to remove the ECU to check if there is any fault in it
Can anyone give me a procedure to remove an ECU.or what else can be fault.
My car model is 2004 Zafira.(Multec)
Thank you very much
Kind regards
Bookmarks
