Results 1 to 10 of 11
Thread: Control Arms
    VXRed MontyPythonX's Avatar
    28th August 2014
    122
    Default Control Arms
    Does anyone know which part of the control arm fails when the knocking occurs?
    18th September 2009
    12,160
    tends to be the ball joint
    I am pretty awesome.
    BOOM
    the Moaning Mod
    Clique No: 7
    28th August 2014
    122
    Ah, right.
    So getting these wouldn't help? :P
    http://www.pedders.com/urethane-lowe...kt-ep6561.html
    18th September 2009
    12,160
    nope
    BOOM
    the Moaning Mod
    Clique No: 7
    18th September 2009
    12,160
    might be worth having a look before you do anything
    BOOM
    the Moaning Mod
    Clique No: 7
    28th August 2014
    122
    Nothing is knocking at the moment.
    I'm just thinking that if I put some coilovers on, whilst the wheel is off and since the geometry will need setting up anyway, I might as well replace the track rod ends and the control arms since the car is over 10 years old now.
    Then I thought if I could upgrade the bits that knock on the new control arms i'd be set for another 10 years at least
    13th July 2009
    47,888
    If you fitting coilovers may aswell fit new lower arms and drop links.
    Ive fitted super pro adjustable droplinks all round great bits of kit. Louise at mwperformance can sort you out with all you need.
    28th August 2014
    122
    Didn't consider the drop links. I'm not after a track car with infinite tunability so may give the adjustable ones a miss, but will look into getting some new ones none-the-less.
    VXRacing ahead vaxer's Avatar
    3rd April 2010
    723
    Definitely worth checking the top mounts too - this was the main cause of my knocking noises. Much cheaper than control arms too.
    Hoovering up the road
    2007 VXR8
    Walkinshaw Performance Power Pack, Headers and Supersport Cats. Ebay Antenna.
    VXRacing ahead mik_ok's Avatar
    25th November 2011
    687
    Top mounts were the usual issue for me too. Found the pedders ones lasted longer than oem and were v similar price from Monkfish at the time.
    Monty - I still have a pair of new front droplinks. Non OEM - bought off ebay. Never fitted them. If you are interested let me know.
    2017 Jaguar F-Pace 3.0d S for her
    2014 Lotus Evora S (SportsRacer) for him
