Results 1 to 8 of 8
Thread: Rear light mod
    VXRed VikingLammy's Avatar
    31st March 2015
    62
    Default Rear light mod
    So after 2 years of owning the Vectra I thought I’d try something different.
    I wrapped the rear chrome strip so it’s colour coded, spray tinted the rear indicators and done the rear light mod.
    Well happy with it and I wish I did it sooner.
    All it involves is swapping 2 pins on drivers side and 1 pin on the passenger side.
    What’s everyone’s thoughts?
    Are you VXR enough? Jon1796's Avatar
    24th August 2015
    817
    Nice one !!!
    More info on the wiring would be nice 👍
    31st March 2015
    62
    Just follow the instructions above. It’s very simple to do, just need to be very careful when removing the pins.
    I used a very small flathead screwdriver, like the ones you get from crackers and some long nose pliers.
    Unfortunately I managed to pull and snapped the wire away from the spade connection on my very first attempt so I ended up cutting both wires on the drivers side and join them bonded them together. I had to use a small piece of tin foil for the snapped wire to reach the already connecting spade.
    Passenger side just need one spade removing and putting it into the empty connector.
    VXR enough V6spike's Avatar
    18th May 2013
    1,641
    Not for the estate though
    '55' Black Vectra VXR Estate. soon to have the goodies from the old beast....
    12,917
    Looks quite sweet. If I had a vec I'd look at doing this.
    VXRed jevienju's Avatar
    18th September 2014
    237
    Looks good! Nice work
    Enviado desde mi SM-T580 mediante Tapatalk
    My Zafi OPC presentation and evolution http://www.vxronline.co.uk/forum/sho...756-My-new-bus
    1st August 2016
    231
    Yup, mod been around for years detailed on Vec c. Not seen anything like this for estate as light positions are different anyway.
    Vectra VXR estate 07
    31st March 2015
    62
    Quote Originally Posted by V6spike View Post
    No, I forgot to mention this is only the hatch version and not the estate.
