Results 1 to 3 of 3
Thread: Pre cat delete
    24th December 2017
    3
    Default Pre cat delete
    Hi just wondering if anyone knows what size the v band clamp on the pre cat is? Looks as if I'll need to replace it when fitting the cat delete. Cheers
    VXRed Wallace-vxr's Avatar
    4th January 2017
    91
    Quote Originally Posted by Atk View Post
    Hi, I done mine last year and used the clamp that's all ready there. You should be able to do a straight swap long as your carefull. Good luck with the old bolts, they are a bugger 😁
    Sent from my G8141 using Tapatalk
    4th January 2017
    91
    Enjoy the pops
