Results 1 to 7 of 7
Thread: Exhaust sound
    2nd January 2018
    8
    Default Exhaust sound
    Newbie here!! Does anyone know of a way to keep the exhaust noise in idle the same as when it starts up cold? Maybe it is just the temperature??
    Sent from my SM-G950F using Tapatalk
    18th September 2017
    479
    Think that’s impossible as when you start from cold it will have choke on then as it warms up the choke will drop off so without speeding your revs up constantly then no you won’t be able to. Welcome to the vxr group tho
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, front mounted intercooler. Running stage 2 map dyno tested at 290bhp 340 lb torque.
    2nd January 2018
    8
    Maybe look into a new exhaust!! Something a little meaner!! Cheers!!👍
    18th September 2017
    479
    Yeh most folk go for a bigger exhaust. When changing you’ll need to look into turbo back exhaust which is normally the exhaust people go for. Remus used to be very popular but I’m pretty sure they aren’t made anymore. Piper is the most used one for the (h) model. Turbo back gives it a definite beefier noise tho
    18th April 2016
    181
    Quote Originally Posted by Damo24LFC View Post
    Wg motorworks can up the Rev range on idle it will be mapped in if this helps pal
    VXR enough Cal93's Avatar
    14th August 2011
    1,163
    Quote Originally Posted by reigatedan View Post
    Why would you want to do that though?
    VXRacing ahead Giancarl03's Avatar
    18th February 2014
    549
    Quote Originally Posted by Cal93 View Post
    Agreed. This is not going to give you that deep growl sound. Just an irritating high pitched rev sound. It only makes the deep growl on start-up as the the air fuel ratio is richer to protect the internal components. It aids with lubrication and slower temperature fluctuations. Most modern performance cars do this.
    -=2014 Astra OPC=-
    Summit White|Aero Pack|206kW|400Nm|1530kg
