Results 1 to 10 of 31
Thread: AFL retrofit
    VXRed MbrownVXR08's Avatar
    10th October 2016
    187
    Default AFL retrofit
    I am looking at buying a a cheap 1.8 for a winter car that has the factory afl’s fitted. I have seen plenty of retrofit threads and a couple of how to etc but as I will have everything on the 1.8 to swap with the vxr can it be done quite simply? Anyone done this and can offer some advice?
    16,518
    Simply I'd say no mate. Fusebox needs to be able to accommodate it, there's a control unit that mounts behind the glove box, a light sensor that attaches to the rear axle and all the wiring fed through and connected up to accommodate it. Then it needs tech2 to enable the afl function.
    10th October 2016
    187
    I have read through a number of different threads and how to threads and expected as much. Have you done them on yours?
    16,518
    No bud. Came with them from factory. Didn't even realise initially then found out they were a sought after extra.
    10th October 2016
    187
    Don’t suppose there is any chance of the wiring already being there? Lol the power fold mirror ones are on a push button I believe lol wishful thinking I know 😉Any suggestions on who could help me?
    16,518
    It's gonna depend what was pre installed from the factory on your car mate. If it's a later model it's more likely to have various looms etc pre installed. Best bet would be to try go to a tech2 specialist like pecky who would be able to tell you what you need. He actually does afl retrofits too I believe.
    16,518
    Power fold mirror looms were pre installed in every model 07ish onwards I believe. That's a simple one, but afl is a bit different
    I retrofitted powerfolds no worries.
    10th October 2016
    187
    It’s 2008 so later but I wouldn’t know what I was looking at 100%. Where is he based? Does he have a website or way of contacting him please?
    16,518
    Wolverhampton mate. He's on here but not too frequently there days. His website is called tech2 guru. Just type it in and you will see. Select astra h and it'll give you a list of all retrofits he does and what's involved.
    16,518
