Results 1 to 10 of 13
    5th January 2018
    6
    Default Boost surgeing issue
    https://youtu.be/rjgFHQKQgIw
    Any ideas on what could be causing it ?
    18th September 2017
    481
    It’s hard too see but how’s it driving in general and what’s exactly happening
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, AIRTEC Stage 2 FMIC. Running stage 3 map dyno tested at 309BHP 355 lb torque.
    Are you VXR enough? andy-'s Avatar
    12th May 2010
    906
    Dunno but I think you need brake fluid (light on dash is the brake warning one)
    Previous Astra H and Vectra VXR owner.....
    5th January 2018
    6
    Quote Originally Posted by Damo24LFC View Post
    semms alright tbh part from setting off n sometimes when pressing back down on accelerator it will serge boost then die down again , but while driving like going to over take boost will start to come on then it will just ccome on and off like its trying to but just carnt quite do it like if you listen to the engine as you watch the boost gauage
    5th January 2018
    6
    Quote Originally Posted by andy- View Post
    i caught the handbrake a bit thats why it came on
    14th September 2016
    58
    Mine is doing the exact same mate and been told its the boost control solenoid situated on the turbo
    5th January 2018
    6
    Quote Originally Posted by Rabbit_vxr View Post
    already changed it mate but still the same
    5th January 2018
    6
    no stored fault codes eather
    VXR enough chodiddly's Avatar
    12th December 2015
    1,647
    cud it be a slight tear in the recirc valve? i know when mine tore i was gettin turkey noise but mine was more than a slight tear lol
    Vac lines all gravy?
    11th July 2017
    332
    do your self a favour and delete that video asap ...2 offences plain as day...never ever show the speedo for a start
    But anyway...yeah looks like either the boost valve is opening early due to the map sensor thinking boost is higher than really is so may need a new Map sensor Or
    Wastegate spring could be getting tired and opening on its own under boost.
