Results 1 to 10 of 10
    6th January 2018
    5
    Unhappy Insignia vxr 59 plate knocking noise!?
    Hi guys
    Iím new here have owned my siggy for about 5 months now and I love it!
    But here comes the first problem lmao
    Thereís a knocking noise coming from the front, sounds to me like a broken spring but Iíve had it looked at and the springs and mounts are intact.
    The guy at the garage mentioned something to do with the drivetrain? But Iím not mechanically minded and could do with some advice as to what it might be?
    Thanks in advance!
    17th September 2011
    948
    Could be several things... A worn bushing, a driveshaft, the flywheel. Very hard to say from your description.
    6th January 2018
    5
    I can only hear it when Iím on a car park Iíll see if I can get a video up on here
    VXR enough AJG's Avatar
    10th January 2010
    1,304
    Quote Originally Posted by Connorg91 View Post
    Don't go into car parks!
    Sounds like it might be the dual mass flywheel (DMF) which is part of the clutch assembly. The DMF has rotationally mounted springs to damp the torque on take off. If the spring/springs break, the DMF and clutch still works, but you can get a rattle on tickover. Plus the clutch biting point can be a little bit jerky to engage.
    6th January 2018
    5
    Haha I thought about doing that aj 😂 Iíve tried to upload a video but as im using my phone itís being a pain,
    Itís worse in reverse than forward and much worse when the steering is fully locked and then as I turn the wheels back it does it again
    10th January 2010
    1,304
    Haha I thought about doing that aj 😂 I’ve tried to upload a video but as im using my phone it’s being a pain,
    It’s worse in reverse than forward and much worse when the steering is fully locked and then as I turn the wheels back it does it again
    Hmmm...Is it just a noise; or does the car crab and judder when on full-lock slow turns?
    6th January 2018
    5
    Quote Originally Posted by AJG View Post
    Just a noise it seems to drive fine mate
    10th January 2010
    1,304
    Possibly front drive shaft CVJ's
    6th January 2018
    5
    Someone else has mentioned cv joint as well mate I managed to get a video on Facebook, Iíll try and it in Monday thanks for all the help 😎👍
    10th January 2010
    1,304
    Could also be worn brake pads. That has come up before.
