Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 54
  1. #21
    15,464
    Hmm. How can you tell? I mean, it rotates freely enough.
  2. #22
    19th January 2014
    1,814
    By the weakness of the handbrake. Caliper pistons and slide pins should be inspected. They're more likely than stretched handbrake cables.
    OPC ÉIRE
  3. #23
    15,464
    So I gotta remove them. What would it look like if it is?
  4. #24
    18th September 2017
    479
    This is the 24hour update
    All is fine with the car no new symptoms to complain about as of yet but there is still time left in the day to find something
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, front mounted intercooler. Running stage 2 map dyno tested at 290bhp 340 lb torque.
  5. #25
    15,464
  6. #26
    VXR enough Jon1796's Avatar
    24th August 2015
    1,109
    As vexer said check calipers , where cable joins caliper it pulls the lever that shaft corrodes also pitting on cylinder/rust. The golf’s were terrible for calipers seizing up.
    Just take rear wheels off and remove cable from caliper and see how freely it moves.
    Also crap/rust by pads remove pads clean the edges a bit off copper lube on the back and clean carrier so they can move freely.
  7. #27
    18th September 2017
    479
    My new washers and engine bay
    Not quite as tidy as yours but I’m defo going to work on it
  8. #28
    15,464
    Cool. Same as mine but mine red obvs
  9. #29
    15,464
    I'll probably just spray it all down with brake clean too.
  10. #30
    19th January 2014
    1,814
    Duuuuuurty
