Results 1 to 10 of 18
Thread: Hid lights
    18th September 2017
    479
    Default Hid lights
    Are these easy to fit and am I right in saying that hids are xenon or are they different
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, front mounted intercooler. Running stage 2 map dyno tested at 290bhp 340 lb torque.
    15,479
    Depends what you do. Many just use the bi xenon light units that come with the afl setup. Although being genuine vx units they are quite pricey.
    18th September 2017
    479
    Think my lights at the minute are standard ones with ice white bulbs they aren’t very good
    15,479
    https://m.ebay.co.uk/itm/Vauxhall-As...gAAOSwyXNaISxX
    These are copies of the vx units. Never seen them in the flesh but look pretty spot on. Maybe they would be okay. Keep in mind that's the price for only one lol
    18th September 2017
    479
    Cool cheers are they plug n play or do I need to sort anything else.
    15,479
    As far as I can see you can just plug and play. They take the same d2s bulbs that my afl's take. With h7 for main beam and t20 for sidelights.
    15,479
    https://m.ebay.co.uk/itm/Nighteye-H7...gAAOSwehZaTfL6
    A cheaper alternative might be to try these out. These are mega bright, however my afl wouldn't accept them. Not sure if it was just because the afl system is picky or whether it was just an issue with the whole astra canbus.
    18th September 2017
    479
    NIce and they just replace the bulbs in now do I need hi beam and lo beam ones or just the hi beam
    15,479
    Probably need h1 aswell for main if I remember correctly.
    18th September 2017
    479
    Cool cheers buddy, what you do for graft
