Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 42
    18th September 2017
    296
    Wink MAP sensor on top hat
    Anyone any ideas about this sensor.
    W20ADM I know you’ll probably answer this
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, front mounted intercooler. Running stage 2 map dyno tested at 290bhp 340 lb torque.
    12,869
    What do you mean by "ideas" mate? You suspecting there's a problem with it as usual?
    18th September 2017
    296
    YEH but honestly there is so something I just don’t know what yet I’m 100% sure there’s summit not working right. What does it do and do you know the symptoms of it not working properly
    18th September 2017
    296
    But if ya getting sick off me just tell me to do one I don’t mind
    12,869
    Do one
    Lol, don't be daft. It's called the manifold absolute pressure sensor. As the name suggests it records the pressures coming through the boost pipe and sends it to the ecu to regulate timing etc.
    18th September 2017
    296
    Ok think I’m Gona changed it lol.
    I’m still getting slight hesitation on slow acceleration at 2.5k hesitates for split second it’s like I release the pedal then put it down again
    12,869
    Do you have a direct route intake?
    18th September 2017
    296
    Not sure, I’ve got a pipe from front mounted intercooler to the top hat.
    Whilst I mention top hat is there any point in me changing it to an enlarged top hat or will it not make a lot of difference
    18th September 2017
    296
    I’ve got a crossover delete pipe on to cone filter
    12,869
    I'd definitely change tophat and power pipe mate. Will improve response. I'll take a pic of my bay at some point and show you my setup.
