Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 42
  1. #21
    VXR enough chodiddly's Avatar
    12th December 2015
    1,380
    You'd just need the correct silicone join. That mtc link comes with the standard join I think. The airtec comes ready to fit straight to the airtec cooler it seems. But there'll be listing for both standard and aftermarket
    ah so best thing if i got an airtec intercooler wud be to stick to the airtec pipes too.
    what i might do then actually is when i order my intercooler ill order the pipes at the same time so it should all match up and that
  2. #22
    12,937
    The mtc pipes match perfectly with the airtec. That's the setup I have.
  3. #23
    12th December 2015
    1,380
    oh right lol i was just thinking if im doing one airtec do em all airtec.
    ill keep that in mind when im doing my ordering cheers mate
  4. #24
    12,937
    Quote Originally Posted by chodiddly View Post
    First time I'd seen that airtec one on ebay.
  5. #25
    18th September 2017
    313
    Perfectly normal. Gonna start calling you a negative Nancy worry Murray at this rate
    Reason I worry is I’ve never had the best luck with engines lol. I think I have a vac leak on a line somewhere I can hear hissing but can not locate it properly so Gona change the lines
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, front mounted intercooler. Running stage 2 map dyno tested at 290bhp 340 lb torque.
  6. #26
    12th December 2015
    1,380
    Quote Originally Posted by Damo24LFC View Post
    it helped me changing the vac lines as i cud just follow them myself too see if everything was clipped in properly i went from standard to green
  7. #27
    12,937
    A hissing when?
    You got a snake under your bonnet? Prank from a mate may ....
  8. #28
    18th September 2017
    313
    Right I’m no talking anymore I can tell your getting sick of me haha. The car is fine runs a dream it’s just me I’ve came to that conclusion.
  9. #29
    18th September 2017
    313
    Quickly cleaned and dried before full darkness set in
  10. #30
    12,937
    Don't be putting swirls into that paint ....
