Results 1 to 10 of 12
Thread: Longdog12
    17th October 2017
    1
    Default Longdog12
    My vxr Astra is currently pushing 265 bhp it's been stage one remapped and had a scorpion exhaust system what should I do next?
    Are you VXR enough? COSWORTH's Avatar
    17th July 2013
    932
    Drive it til the wheels fall off!
    18th September 2017
    296
    Crossover delete and cone filter or cdti airbox, enlarged top hat then stage 2 re map which will give you somewhere near 290
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, front mounted intercooler. Running stage 2 map dyno tested at 290bhp 340 lb torque.
    7th November 2014
    338
    As damo says and a decent intercooler.Once you have the power look at rarb and lowering
    18th September 2017
    296
    If you get front intercooler you can then push for stage 3 which would give you just over 300
    Regional Assistant - South Essex nurburgring24's Avatar
    13th September 2008
    19,834
    Bigger brake set up , best mod
    7th November 2014
    338
    Im running 310 and gotta say that I wish I had bigger brakes.
    Too much ££££ for me tho
    18th September 2017
    296
    It’s around 900 for bigger brake setup is it not
    15th May 2013
    17,158
    Quote Originally Posted by Dalekboy View Post
    Other way round. Look at the handling then add power.
    RARB is first thing anyone should consider regardless of adding power or not
    VXRed blooded tye_time's Avatar
    24th February 2017
    394
    This. I made sure the handling was on rails before thinking about power
