Results 1 to 6 of 6
    Are you VXR enough? COSWORTH's Avatar
    17th July 2013
    936
    Default Fog lights not working
    Hi all
    My fogs have decided not to work.
    Tried new 15 amp fuses.
    Checked wiring connections.
    When I take out fog light relay and when I put it in I hear it clicking.
    Fog light symbol appears on dash when I use the switch.
    Any suggestions?
    Cheers.
    20th January 2014
    1,685
    Assuming that both bulbs don't happen to be blown, you'll need to check it out with a test lamp.
    6th February 2008
    15,843
    As above, you need to fault find it with a test lamp , multimeter
    17th July 2013
    936
    Cheers will try
    A new switch and new bulbs tomorrow - rob them off my other car and see what happens
    25th July 2013
    46
    Might be the relay, even though you can here click !
    17th July 2013
    936
    Yeah will whip that off the other car too will try that before I try switch or bulbs
