Page 1 of 9 1 2 3 ... LastLast
Results 1 to 10 of 87
    18th September 2017
    480
    Default Urgent help required
    Tonight driving home sensibly at 60mph 2k revs and bang all power went tc light on eml on tried pedal test and it came up with the following 42011, 160639
    I know 42011 is cat efficiency but I cannot find what the other one is anywhere.
    I turned power off and turned engine back on and all power back still a little hesitant around 2k revs as if it’s holding back for a split second, but the eml is still on but tc has gone off.
    Can anyone please help me with this thank you
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, front mounted intercooler. Running stage 2 map dyno tested at 290bhp 340 lb torque.
    17,088
    Sounds like exactly what happened when my first maf blew, but you've just replaced that :/
    Have you checked the coilpack for any damage?
    18th September 2017
    480
    Not had a chance I’ve literally just got back at 12. Don’t suppose you know what that 160639 code is I couldn’t find anything anywhere oh and that code only comes up on pedal test not the obd for some reason that obd isn’t bringing anything up code wise
    17,088
    Well its obviously had a wobbly gone into limp mode. You'll first need to check all the ignition equipment again and go from there. It's highly unlikely to be anything serious. I'd be looking to get that oe coilpack in as soon as you can.
    Check the plugs too. What did you say were the plugs again?
    18th September 2017
    480
    They are ngk platinum tipped ones hoping the coil pack comes tomorrow if not it will be thirsday but I’m not driving far til next Thursday now. On the plus side I got 35mpg tonight lol
    17,088
    http://www.astraownersnetwork.co.uk/.../t-106201.html
    P1606 - engine torque not plausible :/
    ****** knows what that means
    Can see it if you scroll down to leh. Quite far down.
    18th September 2017
    480
    If coil pack doesn’t sort it and New plugs looks like it’ll be a trip to the garage was hoping to sort it my self to be fair but I do not have a clue what that means you’ve just found lol it doesn’t make sense
    17,088
    It's generally always fancy speak for "a particular electronic sensor can't read summet". but it uses big enough words to convince people to panic and visit a dealer .....
    17,088
    I'm confident if you have oe plugs, coil, maf, 1st lambda all working there will be no issues.
    coil is the last piece. Really can't see what else would cause this. It's always the engine panicking if a sensor can't read what it wants to properly
    18th September 2017
    480
    Cool cheers. Lamda might be next thing, just found something about someone had similar problem and their garage changed vacuum pipes and it worked could it be possible that one is split but not hanging off as I’ve checked 4/5 times for dangling pipe but they were all connected
