Page 2 of 8 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 79
  1. #11
    18th September 2017
    313
    I feel like I’m being a right pain in the rear it’s horrible having to pester folk for info
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, front mounted intercooler. Running stage 2 map dyno tested at 290bhp 340 lb torque.
  2. #12
    12,937
    Well if all that I've mentioned is in order I can't really think of anything mechanical that would cause this kind of problem, unless parts blew off your engine lol
  3. #13
    18th September 2017
    313
    Quick update came to the car this morning and no eml, back to the way it was driving before it happened
    Hoping coil pack comes today to fit it tonight
  4. #14
    12,937
    That's the next step mate.
  5. #15
    18th September 2017
    313
    Good news coil pack has arrived all the plugs looked in good condition and the coil pack is fitted.
    Bad news it’s still not playing ball what lambda sensor do I get is it Bosch still
  6. #16
    12,937
    Hesitating? The gapping was altered on the plugs wasn't it? That's something that'd bother me. I just get a new set, bang them straight in, after a quick visual inspection.
    The lambda would be the first one. And yes it's bosch.
    Although without fuel trim codes I'm not sure the lambda is a problem ...
  7. #17
    18th September 2017
    313
    Gapping was altered from 0.8 to 0.63 as it was doing it when they were already 0.8 I’ve bought a 2nd hand lambda rather than new just to test it. I’ll change plugs then ngk platinum are the correct ones
  8. #18
    12,937
    Yeah ngk R or platinum as they're also called.
  9. #19
    12,937
  10. #20
    18th September 2017
    313
    Great thanks can I ask tho if my car was running iridium ones before they were changed would my car not of been mapped to use those ones or was it just by chance that time they worked as I’ve heard nothing but bad things about the iridium ones
