Page 3 of 9 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 87
  1. #21
    16,917
    Can't really map it to a certain set of plugs bud. They all give an ignition spark. It just seems to be a computer compatibility thing.
    That's the thing with taking it to a mechanic. There's no mechanical faults to speak of, so it'd be pointless.
  2. #22
    18th September 2017
    480
    New plugs fitted still the same got that lambda sensor coming tomorrow other than that I’m going to have to change boost solenoids next I’ve got a vac box ready to try aswell
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, front mounted intercooler. Running stage 2 map dyno tested at 290bhp 340 lb torque.
  3. #23
    16,917
    Is it a boost issue then maybe. Is ignition ok?
  4. #24
    18th September 2017
    480
    Ignition starts perfect only issue is driving. Just been under the car now and the vac box says top on it but it’s closest to the floor would that be a problem or is that the way round it goes
  5. #25
    16,917
    Can't say tbh mate. Can't say I've really noticed lol.
  6. #26
    18th September 2017
    480
    To be fair I only started with this problem after the coilpack and spark plug change first time round but it obviously cannot be that. It seems like the throttle is closing slightly then opening again
  7. #27
    Are you VXR enough? Mattyslost's Avatar
    2nd May 2015
    877
    Is the MAF the right way round?
    Big Build Astra VXR Instagram - Mattyslost[/COLOR]
  8. #28
    16,917
    Quote Originally Posted by Mattyslost View Post
    This is a good point.
  9. #29
    18th September 2017
    480
    Definitely the right way round arrow towards the turbo
  10. #30
    18th September 2017
    480
    If it’s was in backwards would it not of had tc light and eml on
