Page 5 of 9 FirstFirst ... 3 4 5 6 7 ... LastLast
Results 41 to 50 of 87
  1. #41
    17,580
    Quote Originally Posted by GPH69 View Post
    I would of said a faulty injector causing this problem , I’m no mechanic but am an engineer in electronics and you may have a blocked or tired injector which may be causing this so check connections or take them out and get them cleaned , or it’s a dodgy map?
    This is the problem when you don't get the map info. At least if he knew where it was done he could give them a call and verify it.
  2. #42
    18th September 2017
    481
    Ok now then injectors is that an easy thing to get to and clean or change as I myself is no mechanic too ha I’ve got somebody saying faulty boost solenoid, the thing is I cannot see it being the map as it ran fine when I got the car up til the coil pack went all together.
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, AIRTEC Stage 2 FMIC. Running stage 3 map dyno tested at 309BHP 355 lb torque.
  3. #43
    6th February 2008
    15,968
    Injectors are not a DIY replacement, as there need programming into the car via Tech2. Each injector has a code relating to performance, and this gets coded into the car
    Sent from my iPad using Tapatalk Pro
  4. #44
    18th September 2017
    481
    Sounds fun lol so can I try and clean em first tho that be ok
  5. #45
    17,580
    No reason why you can't try a new bcs bud. Thinking about it its a possibility.
  6. #46
    18th September 2017
    481
    So last resort will be injectors I’d say they sound like an expensive job to be done.
  7. #47
    17,580
    It's a dead easy job for a mapping session as they instantly get mapped in lol
  8. #48
    18th September 2017
    481
    Again car has just cut out driving steadily in 6th at around 2k revs hesitates boom dashboards like Xmas lights and same number 1606 which is engine torque not plausible which I don’t have a clue what it means
  9. #49
    17,580
    Still sounds electrical, sensor wise .....
  10. #50
    18th September 2017
    481
    Yeh defo solenoid hopefully arrive Tuesday then after that I’m stumped dunno what other sensors I can change
