Results 1 to 4 of 4
    VXRed Alastair_'s Avatar
    22nd February 2016
    49
    Default Corsa E heated windscreen for a Corsa D
    My last car was a Ford which had the heated front windscreen. Ever since ive had my vxr ive really missed that feature, especially with some of the cold frosty mornings we've had recently.
    My thinking is; would the new heated windscreens from the Corsa E VXR fit onto the shape of the corsa D, and then wire it into the rear de-misting button?
    I would definitely consider this if it would be a straight swap and easily wired in
    Sapphire Black Corsa VXR - Northern Ireland
    20th March 2015
    299
    Theoretically it would work, but I'm not sure if the windscreens are the same...
    Might be worth asking these guys: http://www.heatedwindscreen.com/acat...indscreen.html
    Double Decat | EP Silencer Delete | Remus Cat Back | 5000K HIDs | Boost & Water Temp Gauge | Pressed Plates
    23rd May 2013
    1,821
    Interesting idea and i can see where you're coming from as i've had 5x mk3 mondeos.
    For me its that much of a problem, my 1.6 doesn't come out in frosty weather as i use the 1.4 - it doesn't have a heated screen but the heated seats and steering wheel more than make up for it
    6th February 2008
    15,843
    The cost of replacing the windowscreen will be very expensive
