Results 1 to 10 of 10
Thread: Need help!
    VXRed J_rns's Avatar
    8th December 2017
    35
    Default Need help!
    Driving normally yesterday then gave it some boost, suddenly EML flashing, no power and misfiring. Turned it off and back on again, only difference is that it misfires only on boost now. Coil pack or plugs? or something else?
    Stock Corsa VXR Arden Blue
    __________________________________________________ ________________
    Stage 3.5 Arden Blue Edition VXR 333 bhp 351 lbft SOLD
    Stage 3 Sapphire Black VXR SOLD
    Are you VXR enough? andy-'s Avatar
    12th May 2010
    906
    get the code read, most likely the coil pack though very common to go on a H VXR
    Previous Astra H and Vectra VXR owner.....
    18th September 2017
    481
    Yeh coil pack and plugs change em both at same time get Bosch coil pack and ngk laser platinum plugs
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, AIRTEC Stage 2 FMIC. Running stage 3 map dyno tested at 309BHP 355 lb torque.
    8th December 2017
    35
    Yh read the codes as soon as with *****. Codes were just misfire on cylinder 2. Today going to change both plugs and coil pack. Going to be using BKR7EIX and a geniune bosch out of a running car.
    26th February 2012
    1,772
    http://www.ebay.co.uk/itm/Z20LET-Z20...-/253363280177 these engines only seem to like standard plugs from ngk
    18th September 2017
    481
    Yeh use ngk laser platinum only £26
    8th December 2017
    35
    New coil pack still misfire. BKR7EIX still misfire, bought the Standard VXR plugs. Will know by the weekend when they come. Btw you know the rubber seal inside the sparkplug socket? whats the part number for it?
    16th December 2018
    24
    Did you sort this mate?
    I've started having the same issue tonight.
    Sent from my SM-N950F using Tapatalk
    17,580
    Looks as though the car is sold mate looking at his signature.
    16th December 2018
    24
    Ah ok, can't see the signatures on Tapatalk.
    Balls.
