Results 1 to 6 of 6
Thread: Remaping
    14th July 2017
    35
    Default Remaping
    i have astra h opc have all this done have :
    cylinder head polished port
    stem seals updated
    all gaskets replaced
    miltek full exhaust system
    cross over delete kit
    fmic running stock turbo at 1bar ...
    frist dyno run was 235bhp at wheels an 265bhp at engine is this stock or did it change an 243fpt
    after mapping it 245 at wheels and 280bhp at engine at 1.5 bar boost drops off to 1.2 after 5k
    he said hes goin to look at the runs and maps and get back to me as he said we car get more easy out off car
    whats the max boost before rods go etc
    18th September 2017
    480
    SOMeone mentioned the other day about torque over 340lb is a ticking bomb on standard rods
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, front mounted intercooler. Running stage 2 map dyno tested at 290bhp 340 lb torque.
    11th July 2017
    326
    Thats pretty low torque results for stage 1...always seen figures closer to 280 or 290fpt so definitely more to come once he mods the map to your car mods.
    Boost pressure wise on the stock turbo its about a match...turbo max's out close to the rods normal limit but all depends on the rest of the engine...ie mileage and history for good oil changes and considerate driving style.
    14th July 2017
    35
    torquw after was 330 ....215k km engine is 180psi across all 4 ....i drive normal 2k rev change gear ever now again wack it
    11th July 2017
    326
    Sounds pretty good then.
    14th July 2017
    35
    are these good figures cause i see people running 280bhp with just exhust sytem but is that 280bhp at wheel or engine ...im confussed
