Results 1 to 3 of 3
    11th January 2018
    2
    Default Pipe keeps disconnecting!
    Hi all! Iíve got a 07 Corsa vxr and the last couple of days I keep having a pipe disconecting every time I put my foot down which stops my boost gauge reading boost so today I put a cable tie on it to prevent it coming off and I lost boost altogether and had the ESP light come on. After removing the cable tie I had boost again and the ESP light went out after switching off the engine and starting it up again....any ideas anyone as itís really frustrating me 😡
    I ha e a couple of pics to show what pipe it is so will try and upload them
    11th July 2017
    326
    To me that means the hose is blocked and causing overboost so limp mode kicks in.
    9th January 2017
    816
    To me that means the hose is blocked and causing overbooked so limp mode kicks in.
    This ^
    Replace the old thin hoses with silicone boost gauge hosing, cheap option to try before anything else.
    Silver Lightning Corsa VXR
