Results 1 to 4 of 4
Thread: No boost!
    11th January 2018
    2
    Default No boost!
    I have seemed to have lost all my boost from my turbo and keep reading on here about collapsing air intake pipes I’ve checked mine and they seem sturdy does anyone have an idea what other causes it could be?
    VXR enough yodacraig's Avatar
    24th January 2010
    3,018
    Isn’t the vac line to the actuator alright ?? Any lights on the dash ??
    xbox addy -turboyoda85
    YouTube channel :yoda racing
    Instagram yoda_craig85
    18th September 2017
    480
    Have you tried looking at the intake pipes and Erving at same time my mates top hat pipe was collapsing and that was causing the problem but that was on an Astra not Corsa could be a vac pipe dropped off though aswell
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, front mounted intercooler. Running stage 2 map dyno tested at 290bhp 340 lb torque.
    23rd May 2013
    2,335
    You have another post up to do with a vac pipe popping off the inlet manifold. Fix that first before looking for other problems.
    Corsa SRI Turbo (SOLD) and Facelift Corsa 1.4 SE
