Results 1 to 3 of 3
    8th March 2017
    1
    Exclamation Dying right after start up HELP ME.
    Hi guys,
    I need your help. My VXR starts dying right after I started it up. I start up the car, all good, car sounds normal and after 1 or 2 seconds it just die. I tried it maybe 20x and it did the same thing all again, I checked the throttle body and it seems to be ok. Car was absolutely fine when I have parked it into the garage a day before. Any ideas?
    11th July 2017
    152
    Fuel pressure?
    MAF meter but usually there would be a warning light or code to pull
    18th September 2017
    301
    I would check the maf first
    07 Arden blue VXR(H). 3” scorpion turbo back, pipercross cone filter, front mounted intercooler. Running stage 2 map dyno tested at 290bhp 340 lb torque.
