Results 1 to 10 of 19
    VXR enough Sporticus's Avatar
    31st January 2010
    2,242
    Default Top gear slip???
    Morning all, yesterday in a 40mile trip to Sheffield along the M1 I was tootling along at 70 in cruise...pit my foot down to overtake a middle laner and the revs increased but the car barely did. Then the revs dropped to what they should be and the car accelerated at it should have initially. No dramas after that but it did it twice on that run...perhaps once before last week but I passed that off. Any ideas please? Assuming clutch related but low miles for clutch I would say...anything else cause that? Car done 22k...65 plate VXR.
    Cheer all.
    Current: Insignia VXR Supersport Unlimited, Corsa Black Edition 1.4t mapped (157bhp).
    Previous: Astra J VXR white (65), Monaro VXR 6.0 LS2, insignia 2.0t sidi vx-line nav (289bhp), V22VXR Vectra VXR Black, Black carbon Flash Insignia VX-Line Nav...215bhp, Astra Gte 2.0l Bertone! MK1 Gte, MK2 Gte 16v, Vectra Gsi 3.2, VXR8 LS2, Astra VXRacing 483.
    3rd September 2015
    408
    Hi,
    Were you in 6th ? Assuming yes because of the title, what was the revs when you put your foot down ? around 2000-2500 ?
    If you were in max torque range, I am afraid it might be clutch related...
    Was weather particularly humid ?
    31st January 2010
    2,242
    Yes, it was around that Rev range...went to about 3.5/4K before dropping. Was a cold afternoon about 2’c. Seems pretty crap if clutch related at such low miles so a case with VX is warranted I guess.
    17th September 2011
    950
    Has the car been remapped?
    9th January 2017
    822
    Could be a knackered seal that is letting fluid onto your clutch/flywheel causing it to slip.
    Silver Lightning Corsa VXR
    11th July 2017
    332
    Mine did the same at 22k but after a trip to the dealer for another job it stopped slipping... They claim they didn't do anything but its certainly improved
    31st January 2010
    2,242
    Bizarre...driven it a fair bit today and hasn’t done it. Can’t weigh it up.
    31st January 2010
    2,242
    Yes st 1
    17th September 2011
    950
    Quote Originally Posted by Sporticus View Post
    Yes st 1
    The clutch is known to be quite weak, if the car is mapped it will wear out relatively quickly and you could see slip, especially under hogh torque loads. It doesn’t sound unlikely that it has been cooked - but there might be other reasons for it slipping.
    31st January 2010
    2,242
    I have vx involved as I think 2nd gear can be a bit “iffy” for precise selection. Is there an upgrade clutch option out there? Even if it means I pay some towards.
