Results 1 to 10 of 19
    14th January 2018
    19
    Default second decat pipe
    hello all, i recieved my second decat pipe today, shocked by how big it is!!!
    how hard is it to fit? i know there is only 5/6 bolts in total to remove old and install new. but how hard are the bolts to get to and is it hard to seal off? many thanks
    9th June 2015
    380
    It isn't to bad. Be sure and match it up to the existing pipe before removal. Check the size of the bolts. I found out when I removed mine that the bolts supplied were bigger than the ones that came off, meaning they wouldn't go through the holes on my exhaust. Luckily I was in the workshop at work so was able to get nuts and bolts that fitted. Also the hanger was seized so I had to cut that off before the pipe came free.
    14th January 2018
    19
    Cool, I'll give it a go tomorrow. Will I need to use exhaust sealant on it?
    Sent from my SM-G955F using Tapatalk
    14th January 2018
    19
    Also where can I get a Klasen primary decat pipe that you mentioned before? Thanks for your help
    3rd September 2015
    384
    Normally no sealant, either you reuse the gaskets or buy new ones over ebay/dealer.
    Ebay for the FMS decat Downpipe I would say...
    9th June 2015
    380
    I bought a new gasket from my local stealers. The primary you can get direct from Klasen Motors. Their website is in German, but depending on which phone and software you use, it will automatically be translated into English.
    14th January 2018
    19
    got a garage to fit it for me today, wow it bangs loud! cant wait to have the primary cat removed.
    11th July 2017
    307
    Just to clarify... Which cat got removed...?
    14th January 2018
    19
    I removed the secondary cat
    11th July 2017
    307
    I'm still not sure which the secondary is
