Results 1 to 10 of 18
Thread: Dump valve hks
    21st July 2017
    21
    Wink Dump valve hks
    Hello
    I am french and research information on the installation of a dump external valve hks, I m explained, I have condemned the dump valve of origin by a shutter, mounted a silicone hose with dump valve hks but I do not know or connect the pipes I had it connected to the vacuum pipe of the original white dump valve and after 15km the orange light with maintenance key is lit, if you can help me with pictures would be great, thank you
    VXR enough yodacraig's Avatar
    24th January 2010
    3,009
    As far I’m aware fitting the hks to these cars is problematic shame really as they are a nice sounding dv
    xbox addy -turboyoda85
    YouTube channel :yoda racing
    Instagram yoda_craig85
    21st July 2017
    21
    Why that
    21st July 2017
    21
    what should I do to fix my connection problem
    24th January 2010
    3,009
    It’s not the connections it’s the dump valve itself you can’t run them on vxrs
    21st July 2017
    21
    ok thank you, I thought the change if my problem persists, a dump valve forge would be more appropriate?
    21st July 2017
    21
    je viens d installer une dump valve forge et le voyant s allume quand j accelere et s eteind au ralentis, pourquoi ?
    9th January 2017
    800
    Quote Originally Posted by Madmax2574 View Post
    Yeah
    Silver Lightning Corsa VXR
    24th January 2010
    3,009
    My French ain’t great but a vanne de vidange de forge est le problème essayer un bailey
    VXR enough LWeth's Avatar
    26th April 2012
    2,983
    dont bother with a dump valve, they cause issues because the engine likes to have a recirc. Keep the recirc and just put a cone filter on. Similar effect and the car will drive better with the air being recirculated!
    Name's Lewis - White Corsa Burg 279
    Follow me on twitter and instagram - @LNWeth
    Location - Isle of Wight
