Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 61
Thread: P0234
  1. #11
    VXR enough V6spike's Avatar
    18th May 2013
    1,841
    Is it the age thing, lol
    Yeah mate lol
  2. #12
    VXRed FinVectra's Avatar
    27th January 2014
    103
    Hope you can sort the problem!
  3. #13
    VXR enough Jon1796's Avatar
    24th August 2015
    1,596
    Have you got any further yet spike!!!
  4. #14
    18th May 2013
    1,841
    No mate. Went out for a drive earlier on the M3 and it went back to limp mode. Going from 4th to 5th at about 4K revs.
    Car is embarrassing as some turd tried racing me in a 1.9 VXD.
  5. #15
    1st August 2016
    423
    Quote Originally Posted by V6spike View Post
    At least you could laugh as VXD's don't exist so the owner must be a bit doolaa
    Vectra VXR estate 07
  6. #16
    18th May 2013
    1,841
    Honestly mate. Though I clearly got away ****ing car goes into limp mode.
  7. #17
    24th August 2015
    1,596
    The more I read on this, if no pipes are leaking then wastegate fault.
    eBay one for £130 or £600 insignia!!!!
  8. #18
    18th May 2013
    1,841
    So I’ve replaced the actuator. That worked for a while. Really good power but then went into limp mode. Have changed the BCS and wastegate. Though that wasn’t new I couldn’t see why it wouldn’t work. Have ordered a new MAP and will look at a smoke test just to be sure. I think I will have another look at the rear vac pipes just in case but it’s either the map or turbo on the way out.
  9. #19
    24th August 2015
    1,596
    Vac pipes don’t forget the one that runs down the wing d/s to the pump. When you back home could swap from mine to test before you buy.
    Don’t think you replaced wastegate unless you replaced turbo lol
  10. #20
    24th August 2015
    1,596
    I’ve got an old pc with basic oc for ya to test map reading and see boost pressures.
