Results 1 to 5 of 5
    6th February 2018
    31
    Default Cold stat up problem
    https://youtu.be/JKv2agEsq94
    Any ideas what can casuse this??
    Please see link video
    6th February 2018
    31
    Anyone???
    VXRed Brett_VXR's Avatar
    14th November 2017
    159
    Could be MAF sensor.. looks like it’s ticking over ok once it’s going.. does the EML come on when you drive?
    VXR Stage 2 • Courtenay Sport Map 292bhp - 337 lbft
    Courtenay Ko4 • Courtenay Tophat • Scorpion Exhaust
    200 Cell Cat • AEM Filter • Luk Clutch • Luk DMF & Cover
    Forge Recirc • 18” TD Pro 1.2 • Eibach Springs
    6th February 2018
    31
    Hi thanks for a response
    No lights come on. Battery has been changed so the flickering needles on start up has stoped but still sounds as its choking on start up.
    20th March 2015
    360
    Checked your coil pack isn't on the way out?
